Wheel adapters...need Pics and opinions!!
Hey so I plan on getting some Hub/Wheel centric adapter for the rear. I cant stand how far in the wheels are sunk in.
My question is do I get 1" or 1.25"??!!
I dont want them to look goofy since I only have the stocker 16" wheels for now.
Any pics would be great
Thanks!
Thanks!
I got 1.25" to fit my T/A and 2007 C6's last week. Here's what I got and fit perfectly:
http://www.ebay.com/itm/2pc-1-25-inch-5x4-75-to-5-x-4-75-Hubcentric-Wheel-Spacers-Adapters-12x1-5/380654965642?_trksid=p3693.m2452&_trkparms=aid%3D333005%26algo%3DRIC.FIT%26ao%3D1%26asc%3D265%26meid%3D8401191589300049731%26pid%3D100102%26prg%3D1140%26rk%3D1%26sd%3D380654965642%26
Why do generic sizes when you can get exactly what you want!? Get custom! You can measure out how far you want to bring them out (in millimeters.. More precise) and get them made exactly that size. I got mine from Motorsport-tech.com, I'll post pics when I get home.
I think I will try out this site for my spacers. What I don't get is the $30 extra that is charged for selecting a different thickness if purchasing a set of 4 with two of them being different thicknesses. It's $90 for just two spacers, $180 for a set of 4 with the same thickness and $210 for a set of 4 with two different thicknesses. What's stopping me from ordering one set at $90, then ordering the next day another set for $90 if I need different thicknesses?
I don't even remember what I paid at this point, but whatever it was, I'm happy with the product! With the wheel + hub centric design, everything went together with a nice snug fit, and you simply can't beat having them custom fit to your liking.
Just my opinion obviously but stock sized rims/tires pushed out flush with the wheel well will honestly look ridiculous from the rear BUT here is a thread to help you out: https://ls1tech.com/forums/wheels-ti...-trans-am.html
for measuring what size spacer, all you need to do is: get some string, like 8-12" long, and tie something to one end as a weight. you can even use something simple like a binder clip at the end. hold the top of the string against the inner portion of your fender (or wherever you want the tire to come out to). measure the distance from the outermost part of the tire, to the string (in millimeters), and that'll tell you how big of a adapter or spacer you should get... of course you can decide how far you really want to push it with that. Personally I wish I had gone bigger with mine, and If I really liked my wheels and wanted to keep them forever I'd buy new adapters to get them set further out. but I want different rims, so there's no point in wasting money on a second pair of adapters as a temporary thing...
took these when I first got the adapters. at that time, I still had 8.5" wheels all around, the rears are now 10.5" DD of the same style.
Hub-centric = you can see how snug it fits around the hub
Wheel centric = the extended lip you see there will fit snugly inside the wheel
depending on the size of the adapters you use, the existing studs will most likely extend out passed the face of the adapter. depending on how far they extend, you may have to do something about that. Another factor is the wheels. Some wheels have a recessed area which allows for that excess length of the stud. This depth of this recessed area will vary. As you can see in the picture, the 8x8.5" C6Z replica wheels I have for the front, only had about a 1/4" recess, which was shorter than the overhang of the studs, which meant the wheels would not fit over top. In comparison, the stock 16" wheels had about a 1" recess, which would have allowed for them to fit perfectly over top.
that being said, I had to trim down my studs...
I used a multi-purpose tool with an oscillating saw head to cut just the tips of the studs, just enough for everything to fit together fine.
1st pic- shows where I cut
2nd pic- one cut vs one normal
3rd pic- all cut except for one
before/after cutting down the studs so the wheels will fit properly
wheel mounted.. I later painted the sides of the adapters black, so they are less visible (even though they really weren't visible before unless you were looking for them)
excuse my fu*ked up paint. lol
you could actually see the wheels poking out the sides after
current wheels are 295's... going with 315's next time
http://www.flickr.com/photos/la-rue/8076221417/http://www.flickr.com/photos/la-rue/8076221417/ by http://www.flickr.com/people/la-rue/, on Flickr
stockers mounted, with current adapters 27mm front, 15 rear. If i was buying adapters for these wheels specifically I'd have gone thicker.
Wish that post above was here a week ago....
Anyways, is there to buy wheel centric over non wheel centric? I got the hub-centric only ones and I have vibration issues above 75 mph
that's the benefit of wheel+hub centric. everything fits together nice and snug, hub-to-adapter, adapter-to-wheel, which makes everything run smoother. and even though you may only notice it at higher speeds, it's still there at the lower speeds as well. Overtime that can end up causing issues.
and yes, I WISH there was a post with pics like I just posted at the time I was looking into this stuff. the whole damn forum seems to be so against the whole idea of them, because ill-fitting/ non-hub/wheel-centric spacers and adapters have given them a bad name. but it makes a huge difference when you buy the stuff that is custom made to fit your specific setup.
Sure, I could have done that, but it wouldn't offer any real difference, and it would have been more expensive:
-buy the spacers
-buy new extended studs
-take the car to a machine shop, pay to get the old studs removed and the new studs pressed in.
of course if you're doing a small spacer you don't necessarily need extended studs, but for the sizes I got, you would.
also, it's just me, but I like adapters more. Once you bolt those to the hub it's like it becomes one piece, and then you bolt the wheels to that new surface, feels really secure. But with a spacer it's just like a shim sandwiched between everything.
check the top of post #7 for how I went about determining how thick to get them made
-buy the spacers
To Crimson:
THANK YOU!! Ive seen the few other post with select pics about adapters but your single post alone was everything I was looking for, much appreciated!
Your lowered correct? If so how much and did you have to roll your fenders with the adapters??
Im not lowered but will be doing hose mod and koni lower front perch about the same time as spacers. Just dont want to have to roll fenders.
PS: your car has always been one of my personal favorites...Good job on one of the sickest cars ive seen fbody or not!
Yeah, I do think it will look a little goofy but better than how sunken in they are at the moment. Plan on getting new wheels next summer, so I plan on just rocking the adapters now with the stockers and hell, maybe with the 10.5's I get as well!
I bought some 1" adapters from a swap meet, need to get them machined out because they don't clear the hub and the lug nuts won't go all the way in. Once I have them machined out I will post pics
2pc 1 25" inch 5x4 75 to 5 x 4 75 Hubcentric Wheel Spacers Adapters 12x1 5 | eBay
