Sponsored by: DashLynx
Help How to wire in vacuum guage
Old 07-05-2013, 06:08 PM
TxOutlawZ28's Avatar
Question Help How to wire in vacuum guage
Can anyone point me in the right direction where to connect the vacuum gauge wire. I have heard just to run it to one of the sensors but which one and how, Im used to old school Camaro and need guidance. Thanks in advance
Old 07-06-2013, 01:26 AM
LilJayV10's Avatar
Is it electrical or does it have an actual vacuum line?
Old 07-07-2013, 07:53 PM
Electrical
Old 07-07-2013, 10:19 PM
djfury05's Avatar
Post a pic of what gauge you are trying to hook up and all the components that need installing.
Old 07-07-2013, 11:29 PM
LilJayV10's Avatar
I googled "how to wire up a vacuum gauge" and got lots of hits
Old 07-12-2013, 02:14 PM
99WS6MAN's Avatar
How about actual vacuum line?
Old 07-12-2013, 03:08 PM
LilJayV10's Avatar
If it has a vacuum line you will have to "T" into a vacuum source coming off the intake rather it be the MAP sensor or the line going the HVAC. If you use the line going to the HVAC make sure you "T" into it before the one way check valve so you are getting a true reading from the intake.
The electrical versions I've seen use its own MAP sensor. I don't know if you could use the MAP sensor already on the car or not. I "think" the only way it would work is if the gauge uses the same voltage table to determine vacuum/boost. I do not know if there's a standard for those values or not.
Old 07-12-2013, 08:41 PM
GoodSpeed150's Avatar
https://ls1tech.com/forums/forced-in...elp-newbs.html
Old 07-13-2013, 08:34 PM
99WS6MAN's Avatar
Originally Posted by GoodSpeed150
Thanks for the help! Looks fairly simple
Quick Reply: Help How to wire in vacuum guage
