Bolt-in shorty antenna SOLUTION for Firebird/Formula/TransAm owners.
Did alot of research on converting my Trans Am from power to non-power antenna. All the diagrams I saw online showed the old style with the nut and washer that goes on top, like this:
Those parts are INCORRECT and requires you to buy more parts than you need! The correct bracket doesn't need to be drilled like I see alot of people say it needs to. The bracket I saw in the older threads is overall LONGER than the stock power antenna assembly (Hence the need for drilling it to bolt it in). This correct bracket is the same length as the power antenna assembly, and is why it's bolt-in. I believe the Camaro non-power antenna bracket is longer than the firebird ones, I just wanted to post this to show firebird owners that there is one made for our cars that's bolt in.
The correct part number for TA/Firebird/Formula owners is 10425535. Googling this number comes up with nothing, and leads me to believe it's either a new part, and/or it supercedes the older brackets.
Here's pics of my install. The top of the bracket is rounded where it goes inside the rubber on the fender, which means it's held on the same way the factory power antenna one is. I didn't get a pic of this, but if people want I will pull it out and put it next to my factory power antenna assembly so you can see it's the same length and fits inside the rubber bushing in the fender just like stock.
Here's pics of mine installed.
This is the diagram I got from my dealer. It's the same diagram for Firebirds and Camaro's, but the part number for the brackets themselves are different between the two cars. And like I said, the Camaro bracket is discontinued. Also note in this picture how there's to nuts or washers, it's just the mast (1), Rubber bushing (2), and antenna bracket (3). See how the top of #3 is just expanded so it sits tight in #2, that's what I was talking about earlier.
I hope this helps anyone who wants to convert from power antenna to non-power. All you need is this bracket, and a screw on antenna of your choise and you're done!
Now for you Camaro guys, did Camaro's have power antenna? I called for the part number for Camaro's, but it's discontinued.
Chris,
Chris,
my factory power is shot, I banged it down and just use my android tablet for all my music, new music sucks and radio reception isn't that good in the mountains even with a good antenna (54 miles birds eye to Chattanooga and 63 miles birds eye to Atlanta) plan is to remove the antenna completely when I get to the body repair/body mod stage of the car.
Yes the numbers are listed in the first post, but here it is again anyways .
10425535 This is for 98-02 Firebird/transam/formula cars only! Once again it's bolt-in. The Camaro bracket is discontinued according to the dealer.
And no I don't mind at all if you link to this thread. Thanks!
Chris,
Chris,
Chris,
I just did this mod 2 weeks ago and yes the Camaro bracket is longer. So you have to drill the hole for the bolt on the bracket higher. This is a great mod and looks 10 times better than the stock one. I got my antenna of Ebay. It is 3 inches high and is black.Functions great/
eventually i found another one back at the junk yard... I was almost certain I got this second one from another camaro, and it fit properly, but perhaps I may have pulled it from a 93-97 firebird instead. Not sure honestly, that was forever ago, and i wasn't looking for it when i found it, just happened to see it when browsing through the fbodys they had
but, I know it was from a 4th gen car and it fit perfectly, just like yours in the pic. I'll get the part number from the one i have in the morning
damn.. think I've been accidentally giving folks the wrong info on my setup. I know at one point in time I had gotten an antenna base from a 4th gen camaro (not sure of year) at the junk yard, but like you said it was longer than necessary. it'll work with little effort, but not the proper fit.
Here's the BitViper antenna I'm using with my car for those who wanted pics. And yes I agree our cars look like RC cars when they radio is on, I HATE the look. My car is at the body shop having the sail panel replaced, and antenna hole deleted right now though
Chris,
