Sponsored by: DashLynx
Warning ! Lowered F-Body and Rhino don't mix !
Old 05-10-2004, 09:22 PM
Fierce-LS1's Avatar
Default Warning ! Lowered F-Body and Rhino don't mix !
Well, I feel like a *&^%(#%$ Moron. I used a rhino ramp to change my oil with my lowered WS6 and after I was done, noticed my front lower bumper had split in a section. The fiberglass literally was ripped into two in the lower section.
Are these bumpers fixable if they break or do I have to buy a new one
How much is a new bumper anyway ?
I just wanted to let you guys know so nobody else makes the same mistake.
My luck sucks
Old 05-10-2004, 09:37 PM
Moderator
jimmyblue's Avatar
How low is low? I'm down 1" (Hotchkiss) and
still have about an inch of clearance on my
Rhinos.
Old 05-10-2004, 09:42 PM
XtinctHawk02's Avatar
Take a pic of that split. Are you sure you didn't split the bumper somewhere else? hit anything on the freeway or anything?
Fierce-LS1's Avatar
Lowered 1.5 inch.
But I took the ramp at an downhill angle
YeAH I'm pretty sure I caused it because I would have noticed it during waxing the day before.
I'll try to get a pic.
Old 05-10-2004, 09:45 PM
2KThunder's Avatar
That sucks. Sorry to hear it, but thanks for the heads up. We have ramps, and I am sure eventually I would have used them. My bumper was cracked when I bought it though. Not seeing how yours is broke, but it is probably not repairable, they usually are not. I was quoted at $600 with paint OEM part. Thats for a Camaro.
Old 05-10-2004, 09:55 PM
Fierce-LS1's Avatar
thanks for the feedback guys. So here is what it looks like
Attached Thumbnails Warning ! Lowered F-Body and Rhino don't mix !-bumper1.jpg   Warning ! Lowered F-Body and Rhino don't mix !-bumper2.jpg
Old 05-11-2004, 04:42 AM
ZR2877's Avatar
That sucks. I always use a jack and jack stands. I always jack it up on the passenger side so the oil runs out better.
Old 05-11-2004, 08:25 AM
Graphite_WS6's Avatar
You can get that fixed. I had a crack similar to yours and my friends bodyshop fixed it with fiberglass from the back side, then repainted the bumper. These bumpers are not fiberglass by the way, they are polyurethane. Fiberglass isn't flexible.
Old 05-11-2004, 08:31 AM
Assassin's Avatar
I have a 2" drop on my camaro and drive it on a couple of 2x4's so the jack can fit under the cross member
Old 05-11-2004, 12:04 PM
Bird_Of_Prey's Avatar
You can tell from the pics that the car has been bottomed out before, why worry about the mark being an extra half inch up?
Old 05-11-2004, 12:06 PM
onyxxtreme's Avatar
check out urethane supply company, they sell all the stuff you need to repair your own stuff. Either get what you need from their online store, or find a local dealer, its the same price either way.
I think polyurethane isn't a thermoplastic, so it cant be welded properly. So basically your stuck with just reinforcing the area (behind)
http://urethanesupply.com
Old 05-11-2004, 12:27 PM
Fierce-LS1's Avatar
thanks...I will give them a try
Old 05-11-2004, 01:48 PM
Ackattack1's Avatar
i use some pieces of wood to extend my ramps so I don't rub like that
Old 05-11-2004, 03:08 PM
Rice Burner's Avatar
through a couple 2 by 4s in front of the ramp, itll clear. have someone watching to make sure. thats what i do and it works. i use rhino ramps for everything and im lowered.
Old 05-11-2004, 03:18 PM
LethalLS1's Avatar
Mine is 2" lower and I can drive straight on and off my Rhino ramps.... however I use two pieces of 2x6 in front of the ramps so not to call it close.
Quick Reply: Warning ! Lowered F-Body and Rhino don't mix !
