How do you remove water spots from glass?
Mother's water spot removes. Works great. I used it with a dual action polisher to remove those stubborn spots. A little elbow grease and you can remove them as well. It's available over the counter.
http://www.mothers.com/02_products/06712.html
OP, what have you tried so far to remove them?
I've had great luck with Glass Cleaner and #0000 Steel Wool and our Paint Polishes with a cordless drill.
Above and beyond what has been mentioned here, you can use a product called Cerium Oxide and Bronze Wool Pad, that's the MOST aggressive approach. It makes an UNBELIEVABLE mess, but it will knock out even the worst etching in glass.
