How to take scratches out of interior piece
When I was putting my roll bar in I put some scratches in my back plastic interior pieces. Is there any way I can take them out? I was wondering about wetsanding them possibly. thanks for any help.
You can take them out slightly buy sanding but you will not be able to match the texture back perfect... try using some really fine grit sand paper. then take a heat gun to the panel...the heatgun will bring the color back to the panel after you sand it. If you have never used a heat gun on plastic before, take your time and do it very slowly...if you spend too much time in one area you will ruin the plastic. Like I said this is not a perfect fix but it will make it look better. It should be close enough that only you know it's there.
On 2nd thought try it with a hairdryer. Less chance of f'n something up.
