Sponsored by: DashLynx
LED gauge lights help!!!!
Old 11-08-2015, 10:33 PM
mcginnis22's Avatar
Default LED gauge lights help!!!!
I have a 2001 z28 and I'm wanting to swap the stock lights for some white led gauge cluster lights. The website that everyone says they got them at all say discontinued now (super bright......com). Where can get these LEDs at a good price and good quality. Thanks
Old 11-09-2015, 02:22 AM
quiet_storm98's Avatar
I just looked on their site abd they are still there i believe these are the ones i bought https://www.superbrightleds.com/moreinfo/miniature-wedge-base/194-led-bulb-5-led-miniature-wedge-retrofit-car/199/ by the way since you have a camaro the gauges have a blue film on them so even though you will be using white bulbs your gauges will light up in a light blue color like the pic
The following users liked this post:
s2000442 (12-20-2020)
Old 11-09-2015, 06:20 AM
Atrus_SS's Avatar
Agreed with the 2nd poster. The blue really doesn't look bad though...anything lookgs better than that OE "dirty green". You'd have to really strip down the cluster and get all the blue "filter" off the gauge face. Doable, but not fun. Also, you will lose your ability to dim the lights. They do, but in a very narrow range. If stock goes from 0% (black) to 100% (bright), I'd say these are like 95% to 100%. They are way too bright at night for me - but I don't like having my dash lights cranked up, even with incandescents. I am working on a solution to that.
This is the stock cluster, cleared of the blue filter, and running the superbrightLEDs cool white bulb-replacement LEDs with some additional peripheral LEDs installed around the perimeter to allow for even lighting. This was me bench testing it in the house before reinstalling.
Old 11-09-2015, 08:05 PM
mcginnis22's Avatar
What are the numbers for the controls on steering wheel, the a/c panel lights and the light switch lights
Old 11-10-2015, 05:57 AM
Atrus_SS's Avatar
There are no numbers for the bulbs in the wheel controls...those are small bulbs that are soldered to the circuit board. I ended up using a few NEO-3's from Superbrightleds that I had to make fit...and then they were too bright, so I had to put in a filter to cut the intensity down to match the rest of the dash.
Rest of the interior - the "plug n play" bits are listed here:
http://6litereaterdesigns.com/forum/...p?topic=1077.0
Old 11-10-2015, 01:31 PM
The ac controls and door panels are #74 bulbs the headlight switch is a neo 3 and like said above for the radio controls you have to solder new bulbs in
Old 01-05-2016, 02:01 AM
gccasper04's Avatar
I used my dremel and a 400grit sanding bit and sanded the red film off my trans am dash cluster. You cant do this with the HVAC/Headlight dimmer overlay as the overlay has the words printed on the back and no the front.
Ive got blues to mach my cobalt gauges.
Here is a crappy cell phone pic after I plugged it in the first time.
Old 01-05-2016, 02:02 AM
gccasper04's Avatar
I could dim minedecent till I added a LED for the bright lights. Then it all went away...
Old 01-29-2016, 08:05 PM
Sabohead's Avatar
Beautiful Cluster! Exactly how i want mine to look in my 02 camaro!!
Quick Reply: LED gauge lights help!!!!
