Depo "Whistler" headlight install
So I pulled the trigger on some depo headlights to compliment the red/black theme going on with my Z28. I was a bit skeptical because I read several had fitment issues. Well I too ended being one of those that had a nice gap between the bumper. I figured I would share what I did to fix it.
Here is how they looked to start.
Now in this pic, I loosened the top bracket that attaches to the core support and pulled it forward far as it would go. Next I added 3- 5/16 washers(grade 8 for no rust) in-between that top bracket and headlight bracket where the 10mm bolt fastens the headlight. This was the end result.
Next I went ahead and adjusted the headlights to the desired height, then I took a long Allen wrench with a ball head and used it to get under the headlight and tuck the seal in the chamfered edge of the bumper. This is what I ended up with.
Thanks! Yea I was holding off on that part because I might get a different hood and have the part behind the grill painted gloss black. I know I could fog it in but I am kind of picky.
Oh and changing those side marker lenses is a bitch. I had to cut some of the bumper foam on mine.
Yea I've had 4 pairs of black housing side markers before and when I install them I usually loosen up the bolts on the bumper and fender attachment and it makes it easier. Is this the first time you've had them? All 4 pairs I have bought suffer from burning and melting of the plastic from heat from the bulb. I just wish someone would make a plug n play LED bulb that fits without additional mods. I went back to stock because I can't find a housing that wont melt and/or an LED bulb that will fit without changing to a electronic flasher control. or using resistors.
Also get an emblem for that grille.
Thanks Phoenix and Necro!!
The depos look real good. Much better than a pair of old, worn out stock headlights and it's surprising how much it improves the look. Like night and day... literally because now I can see
Thanks and I agree!! Actually my stockers are like show room new. Car only has 18k mi and has never even seen rain but maybe a handful of times. Part of the reason why it took me so long to want to change anything on it...finally got bored I guess.
Not a bad way to keep the stocks ones in great condition as well. I'd rather have something bad happen to the replaceable depos than a pair of like new factory headlights.
