2 Issues: Lost screws to Door Panel & Broke clips on Door Panel
Old 08-05-2016, 09:01 AM
RONIN LSX's Avatar
Default 2 Issues: Lost screws to Door Panel & Broke clips on Door Panel
I lost... well my buddy lost the screws that are used to affix the panel to the door, I think there was 4, plus the screw that holds on the back plate at the door handle and lock. Where can I get these screws?
Second issue...
The plastic tabs ( see Pic ) that are molded into the panel, on the back, some broke off so the panel is not being held snug to the door. What do you guy suggest as a fix?
Thanks!
Old 08-06-2016, 07:48 AM
NineZeroFive's Avatar
Junkyard or call Hawks third gen for replacement panel and screws. Easy peasy
Old 08-06-2016, 11:48 AM
RONIN LSX's Avatar
Thanks!
Old 08-06-2016, 11:49 AM
RONIN LSX's Avatar
What about those molded in tabs? Is there a fix for them, if they have been broken off?
Old 08-11-2016, 10:29 AM
bleepster's Avatar
i have the same issue with some of those tabs being broke off. I planned on making new tabs and riveting them to the stubs that are left then epoxying them in place. i planned on using a piece of angle metal bent and shaped to match a good tab. then once epoxied in-place, put a small piece of tubing on it to prevent it from rubbing on the door panel.
i am not sure if this will work, but it was just the first thought i have. something like this made to fit:
Old 08-18-2016, 10:08 AM
FCar2000TA's Avatar
This. I have used Hawks a few times for screws/clips that have gotten broken or lose. Super easy company to work with.
Old 08-18-2016, 05:37 PM
finewayne's Avatar
couldn't agree more, never had any problem with them
Quick Reply: 2 Issues: Lost screws to Door Panel & Broke clips on Door Panel
