Interior Console lights not working.....gear Letters/numbers...PICTURE
Hi guys,
These have not been working since a friend installed my new complete dash. He said he forgot to plug it in. I'm just getting around to asking this.....
Where is the electrical plug located to get these lights working again?
Whats the easiest steps to get to the plug?
Thanks.
Thanks.
The top part of it comes out pretty easily. There's a staple on the front of the shift **** you'll need a flat head screw driver to pull out. Then there are two bolts inside the center console storage compartment underneith the change collector, unscrew those, remove the shift knox..and it comes straight up.
I'll do it tomorrow.
Thanks.
Yes that is correct. There should be a two wires, one black and one light grey connected to a bulb socket. I believe its a 194 bulb. Check around your gear shifter lever and inside of the center console/dash area..it can't be too far. Mine was also unplugged.
