Sponsored by: DashLynx
Wetsanding question...
Old 06-24-2004, 06:15 PM
do0dfromcali's Avatar
Default Wetsanding question...
This doesn't pertain to vehicles as in a ls1, but I am selling my boat in the next couple of weeks and am curious if I could wetsand it to bring back some of the shine.
I this possible and what grit do you think I would need? Also what kind of wax could I put onto it
Old 06-24-2004, 06:24 PM
DARK AGE 53's Avatar
I know zero about boats but I don't think you want to wetsand a boat that is gel coated. JMO
Al
Old 06-24-2004, 06:39 PM
ZaneO's Avatar
To bring back shine you don't want to wet sand. Wet sanding is for removing orange peel and deep scratches.
You want a compound/polish to make it shine again. Most products will work for clearcoats and gelcoats.
www.poorboysworld.com
http://properautocare.com/redugelcofi.html
http://autogeek.net/boatandrv.html
Old 06-24-2004, 06:46 PM
ZaneO Thanks for the links bud. I looked through them and this one caught my eye
http://properautocare.com/smallboatkit.html
Let me know what ya think about that. I am just trying to get the boat cleaned up before I sell it and I think 50 bucks isnt bad to spend to get the boat sold.
Old 06-24-2004, 06:52 PM
Humanitarian
Joe "Preachers Sheets" DIESO's Avatar
3M™ Imperial™ Microfinishing Compound
Specially formulated medium cut compound. Recommended for removing grade microfine 1200, 1500 and 2000 sand scratches in marine paints.
3M™ Imperial™ Microfinishing Rubbing Compound 06011, 1 Quart (US), 12 per case
This should do the trick, 3M makes great stuff.
Old 06-24-2004, 09:23 PM
ZaneO's Avatar
Most anything on those sites that you find will be good, but my question is, do you have a buffer to make them work properly?
Old 06-24-2004, 10:32 PM
I have on orbital buffer, but I am thinking by you asking that, I will need a high speed buffer
Old 06-25-2004, 07:20 AM
Humanitarian
A random orbit buffer is more than enough, rely on the pad, not the machine.
Old 06-25-2004, 07:34 AM
SSZSLP's Avatar
sorry,but an orbital polisher is NOT the one to use
Old 06-25-2004, 07:49 AM
Humanitarian
Fill me in as to why. My Cyclo polisher with the heay cut pad and a compound is almost as aggresive as my DeWalt rotary and it's alot easier to use.
Old 06-25-2004, 08:14 AM
6']['9's Avatar
because an orbital polisher doesnt produce enough heat to remove scratches especially if youre going to wetsand. i can guarantee if you wetsand your cyclo with heavy cut pads wont do much. if you just want to polish it up then yeah use the cyclo but if your going the wetsand route or scratch/swirl removal then id go rotory with a polishing pad and some IP. it wont take as long either since the heat of the rotory will break down the product faster than the cyclo
Old 06-25-2004, 08:21 AM
Humanitarian
He has a random orbit now, I don't see the need for him to go out and spend 200.00-300.00 on a rotary + the cost of pads (15.00 - 20.00 each) just because the random orbit doesnt work as quickly as the rotary but heck, maybe he's got the money to spend.
Old 06-25-2004, 09:55 AM
SSZSLP's Avatar
like the old saying goes if you want it done right,use the right tools
Old 06-25-2004, 10:10 AM
Humanitarian
Doing a job the correct way and spending money to get the job done quicker are two different things.
Old 06-25-2004, 10:15 AM
SSZSLP's Avatar
true,but I don't think this person would want to spend 3-4 times the amount of time,it would take to get the job done,and end up only looking a little better vs. alot better
Old 06-25-2004, 10:32 AM
6']['9's Avatar
i guess it all depends on how much you are going to be making as far as profit goes off the boat. If its a large amount of money then id say go for the rotory and you can practice on it later or just take it back and say you didnt like it. however you can also use your cyclo and a light cut polishing pad if you know your not going to make a lot off the boat.
Old 06-25-2004, 12:55 PM
I appreciate all the feedback guys. Its an 89 four winns speed boat. I just want it to look better then it is now so as to bump up some profit in the boat. Also I might have a buddy with a high speed buffer, so all I would have to do is ask him and I could borrow it. Save myself a couple hundred right? Thanks again for all the help
Old 06-25-2004, 01:05 PM
ZaneO's Avatar
You can't just pick up a high speed buffer and start using it. You will ruin the finish almost immediately.
Old 06-25-2004, 02:01 PM
6']['9's Avatar
well technically speaking you could but how it comes out depends on how much experience you have with it
Old 06-25-2004, 02:08 PM
Humanitarian
Low speeds, waffle pads, dont put pressure on the pad, mist the surface with water and the pad and there is a 90% chance the clear will be safe. It was for more my first time.
Rotary's can be hard to use but if you use a few simple tricks and dont worry about make the surface perfect with a single pass the results can be pretty impressive. I dont use the rotary much on cars because the pads are so awkward.
Quick Reply: Wetsanding question...
