Sound deadening - LS1TECH
Sound deadening
Thread Tools Search this Thread
Old 02-23-2017, 02:49 PM   #1
Default Sound deadening
I'm wanting to make my camaro quieter inside(road/exhaust noise/raido). I'm thinking about Dynamat or some thing like it. I've seen spray in **** but dont really don't know anything about it. I don't want to do any strange **** like I see on U tube. I would like to hear from ya'll about your experiences and any tips that might be useful
2ToeRacing is offline   Reply With Quote
Old 02-24-2017, 08:56 AM   #2
No one....I ordered Dynamat it should be here tomorrow.
Old 02-24-2017, 09:08 AM   #3
ICRAZY6's Avatar
I've used both Dynamat and Xmat from Eastwood. Both are good products. There are a few other thread on here that might be a good read for you.
ICRAZY6 is offline   Reply With Quote
Old 02-24-2017, 09:16 AM   #4
RebelExtrm02's Avatar
Dynomat alone won't do a whole lot. Dynomat is just a sound dampener meant to quell panel vibrations and resonance in the cabin. You'll get the best results using a sound dampener along with a closed cell foam (CCF) and mass loaded vinyl (MLV). The typical plan of attack is to cover about 25% of the cabin surfaces with a sound dampener and then cover 100% with closed cell foam (as a decoupler) and mlv (the actual sound barrier/absorber).
RebelExtrm02 is offline   Reply With Quote
Old 02-24-2017, 12:10 PM   #5
Dynamat also makes a product called Dynapad. It's basically what Rebel just described.
alfablue is offline   Reply With Quote
Old 02-24-2017, 08:43 PM   #6
joeformula's Avatar
I am using dynamat xtreme
joeformula is offline   Reply With Quote
Old 02-25-2017, 09:55 PM   #7
Copy & Paste Moderator
VIP1's Avatar
Quote:
There are plenty of threads on sound deadening. A quick search will find them.
VIP1 is offline   Reply With Quote
Old 02-26-2017, 08:55 AM   #8
I used a product called Fat Mat and you can find it on Amazon. It is a lot less expensive than Dynamat, and in my opinion, it is just as good as Dynamat. Now, asking someone the "best" sound deadening is the same as asking the best cam or exhaust system; you are going to get a bunch of different answers. I probably put over 225 sq feet of Fat Mat in my car, basically putting it on all exposed metal in my car: floor, sides, roof, hatch, doors, etc. Now, I did run out of Fat Mat and I put Dynamat on the interior door skins while I put Fat Mat on the interior of the door on the exterior door skin.
In order to do it right, you need to gut the whole interior. Not only that, when I put in my carpeting, I put down extra insulation and my carpeting has "mass backing". That is a rubberized coating on the back of the carpet. Got the carpeting from stockinteriors. Now, adding all this sound deadening will add weight, but I wanted a quiet interior.
You can see my Fat Mat install in my thread for my Redline Goods Interior thread, post 21.
http://ls1tech.com/forums/appearance-detailing/1815257-my-redline-goods-interior.html
There are a lot of threads discussing this, so look through them and see what matches your needs.
98RaptorTA is offline   Reply With Quote
Old 02-26-2017, 10:57 PM   #9
JDEP162's Avatar
Quote:
this is perfectly accurate. I did have some luck tho coating the entire hatch and doors, both the meat and plastic pieces with cutting exhaust drone, and speaker rattles.
JDEP162 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Stall converters Justin Adams Automatic Transmission 4 02-09-2017 12:17 AM
What is so heroic about crapping your pants? JROC Racer's Lounge 31 08-23-2016 09:58 AM
Hello....70 Monte Tony Bieszk Introductions & Greetings 0 07-06-2016 06:57 PM
idk what to do anymore 97badass Racer's Lounge 28 05-12-2012 02:13 PM
Florida Cracker checkin in deejaydaze Western Members 7 05-25-2008 12:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
