Leds in taillight
don't have pics yet,but the leds do not "flood" the area full of light as the stock bulbs,kind of looks like a quarter sized light beam from behind and you have to use the resistors to prevent your third brake light from being slightly turned on when NOT using the brakes
Copy & Paste Moderator
There are plug-in LED lights, but they dont light-up the taillights well. Since LEDs are highly focused and directionaly, the center will be a bright spot but the rest of the housing will either not be light or be lit dimly. This is, of course, unless someone makes a proper replacement with LEDs facing all directions to properly light up the housing.
There was a discussion a while ago about making a custom unit.
EDIT:
I found the Link:
https://ls1tech.com/forums/showthrea...&highlight=led
EDIT:
I found the Link:
Originally Posted by D_Run
Has anyone tried one of these?
What leds are best to use for the sidemarkers?, i've seen alot of different leds.
