Sponsored by: DashLynx
hood hieght problem , please help!
Old 08-08-2004, 11:39 AM
rayce08's Avatar
Default hood hieght problem , please help!
ive put a factory ram air hood on my 95 and i cant get it lower at the rear , ive got it aligned but at the rear the hinge is to high and it sticks up a bit and i cant seem to get the hinge any lower . is there a trick or somthing im missing?
Old 08-08-2004, 11:55 AM
DrkPhx's Avatar
Have you tried loosening the hinge bolts slightly (do not remove) and adjusting? You might have to remove the hinges and drill the bolt holes to a "slotted" hole to give you some adjustabilty.
Old 08-08-2004, 12:58 PM
rayce08's Avatar
yea thats seems to be my problem , ive loosend the hinge at the hood and on the fender and theres not alot of ajustablity . it kinda like the problem the 2nd gen fbodys had at the back of the hood were you had to push it down sometimes . has anyone else had this problem with there hoods on lt1 or ls1 ram air hoods? i only need like 3/8 inch on both sides and only at the back.
