Door window loose?
Door window loose?
Ive had to replace window motors just like everyone else. But now im noticing that the actual bracket that the motor mounts too is loose. Anyone have this problem and idea's on how to fix it without pulling the door skin off?
When you replaced the window motors did you rivet them in or bolt them in? I used the hardware that was included with the motors I got form Autozone instead of rivets; so I could easily remove them if needed but I did use some light loctite too. If I remember right the motor mounts right to the window regulator, right? The regulator is riveted to the inner door too, I think. There should be some buffers that can be adjusted to tighten the window, check those.
Originally Posted by VIP1
My driver's side window was loose once. It ended up being a worn guide.
