Sponsored by: DashLynx
Gauge Pod Install
Old 08-19-2004, 03:13 PM
...with cheese.
Armageddon's Avatar
Default Gauge Pod Install
I searched up and down for this, before I install my dual gauge pod I wanted to see how people were installing them. I noticed the pillar pod came with something like 4 little press fit clips. I don't see any holes on the pod itself to fasten those with. Is there drilling of the factory pod underneath it to get those in?
Old 08-19-2004, 03:27 PM
Ferocity02's Avatar
You will need to remvoe the factory A-pillar, put the pillar cover onto it, then drill out holes for the pins. You also need to drill larger holes in the factory A-pillar in the middle for the wires to go through.
Old 08-19-2004, 05:19 PM
...with cheese.
Armageddon's Avatar
can you explain to me the easiest way to get the factory one off? what stuff do i look out for?
Old 08-19-2004, 05:23 PM
...with cheese.
Armageddon's Avatar
can you post some pics of how yours looks?
Old 08-19-2004, 06:49 PM
Ferocity02's Avatar
Take off the T-top. There are a couple screws there that hold it on. The front part is tricky to remove. I am not sure if there are any screws there to remove or not. You have to pull the front up and out. Theres not much to it.
Old 08-19-2004, 08:36 PM
SilverSSGabe's Avatar
What do you hook the air/fuel too?
Old 08-19-2004, 09:31 PM
...with cheese.
Armageddon's Avatar
If you are referring to the signal wire... you hook it up to the O2 sensor, preferably through a pigtail that can be had for next to nothing.
Old 08-19-2004, 09:35 PM
Thank you.
Old 08-19-2004, 09:38 PM
Ferocity02's Avatar
I spliced into the violet wire coming off the passenger side front O2 sensor.
Old 05-31-2008, 09:58 PM
Red Devil 99''s Avatar
heres the install
off
on with wheel tilted to show plenty of clearance
from passenger view
Quick Reply: Gauge Pod Install
