Sponsored by: DashLynx
L.E.D turning lamps
Old 08-30-2004, 09:15 AM
BlackEcho's Avatar
Default L.E.D turning lamps
Anyoe use L.E.D for the 3157 turn lamps? just bought another pair of clear corners because of the fukin heat reg blbs give off. i dont htink they will work but has anyone used them b4?
FYI here is a lonk to someone who sells them
http://www.superbrightleds.com/cgi-b...gi?product=CAR
scroll down to 3157.
Old 08-30-2004, 11:55 AM
InfiniteReality's Avatar
I think they should work. Might have to use a 10w resistor or change out the thermal flasher for a electrical one so the car doesn't think a bulbs out from pulling alot less amps. As far as brightness? Who knows, should be the same since LEDs are directional. Only down side I'd see is that you might see a circle of light lit up instead of the whole housing.
Old 08-30-2004, 11:38 PM
BlackEcho's Avatar
thanks.
Old 08-31-2004, 12:37 AM
joedrum71's Avatar
I've got them in mine. Make sure you by amber bulbs or whatever color your turn signals are. DON'T buy white. Buy the most LED's on the bulb you can. I think mine are 18 or something. Go to superbrightleds.com That's where I get all mine. 75% of my lights are LED's. If you put them in the front turns with clear corners, get the multi-directional one's. Mine need to be brighter. Hope it helps. And yes, you should get an electronic flasher(s)
Old 08-31-2004, 10:37 AM
LS1_SS's Avatar
they wil work, but for your turn signals youll need to get new flashers which are like 10$ each from the local autoparts store. remeber LEDs are unidirectinal so i dont think you would want to use them for your brake lights, they would be harder to see
Old 09-02-2004, 09:08 AM
BlackEcho's Avatar
thanks guys. i think i am gonna try to find some multidirectional ones. All i need them for is the front turn signals. damn 3157 keeps burning out on me.
Old 09-02-2004, 10:10 AM
mikes98z's Avatar
Do you have part numbers of the ones you used? I am looking at putting LED's in my front turn signals for my 98Z. I do not have the clear corners, just the factory amber lens. Thanks for the info.
Quick Reply: L.E.D turning lamps
