Thanks ISWON I did the wire mod today
I did the wire mod today thanks to the great instructions ISWON posted.
Thanks ISWON the instructions you posted were great.
1. I did not cut the wires, followed ISWON instructions it works great without cutting the wires.
2. I did not have to use a right angle drill. I drilled a pilot hole from the top, with a short bit and did not have to use a right angle drill, then drilled from the fender well per ISWON instructions.
3. Made a gromet out fuel line.
4. Found the hole plugs at Lowes.
Thanks again to ISWON for the instructions.
Guys it's lswon with an L as in LS1, not ISWON. This is the thread with the instructions: https://ls1tech.com/forums/appearance-detailing/173263-completed-wire-mod-tutorial-inside.html. Just trying to make sure that credit is given where credit is due.
Originally Posted by LS1 Sounds
Guys it's lswon with an L as in LS1, not ISWON. This is the thread with the instructions: https://ls1tech.com/forums/showthread.php?t=173263. Just trying to make sure that credit is given where credit is due.
Thanks for the compliments I was glad the tutorial was able to help you out. I'm in the process of throwing some more tutorials on there, but just haven't had the chance to.
Thanks Again!
Danny
Thanks Again!
Danny
