Gadge cluster
Copy & Paste Moderator
A Corvette gauge cluster will not work in an f-body.
It has been discussed before and from what I remember, they are not campatible and it would take some major work to make them interface.
If you want 200mph gauges, Granatelli can recalibrate your gauge cluster and put on a 200mph face.
I did a quick search:
https://ls1tech.com/forums/showthrea...corvette+gauge
I found a couple more hits, but thats the best I found. I know I read some threads on hear about it, but that was a year a go. Maybe the threads where archived or lost. I guess this is a good time to bring this subject back to the fore-front.
Well I have both (f-body and Z06) and with enough money anything can be made to work but no it will not physically bolt up to an F-body. Plus even if it could be made to fit you'd have to put a corvette computer and sensors and Body module or whatever it is called to make the gauges functional and then you have a wiring nightmare and I suspect you would throw alot of codes.
Again no "expert" information here I have just a limited knowledge on it but it would be a MAJOR undertaking.
If what you need is the 200mph Speedo then go Granettelli I think a Z06 cluster would cost you at least that 250 anyways.
