Trunk Carpet is Soaked!
the carpet in my trunk is soaked! i'm in the northeast and it has rained for almost a week straight and when i went to grab a book out of my trunk i realized it was soaked, along with the carpet. has this ever happened to anyone else? should i be concerned?
Jacob
Jacob
Last summer on my '99 Formula WS.6, same problem. If you open the hatch you'll notice two black "cups" above each tail light. These cups channel runoff water behind the tail lights and out underneath them. There is a small hole in each at the back closest to you (when standing behind car). I'd say either this small hole has become plugged....or, more likely. What happened to mine was that the fit between the metal and the black plastic cup had loosened to the point that I could lift it up slightly with a fingernail. Water gets in through this new seam and goes directly into the trunk. My solution was to hit the local home hardware for some silicone. Since then I haven't had a problem, and I've just moved to the East Coast.....all it frickin' does here is rain. Hope this helps.
thanks for the help... i hope so too. my girlfriends bag was in the trunk at the time. ruined all her books and stained her bag, but at least her laptop is fine. my main issue is that the car stinks to high heavens from it though im gonna try all your fixes and hopefully one of them will work.
Jacob
Jacob
Here's some threads from people who had leak problems:
https://ls1tech.com/forums/general-maintenance-repairs/188629-all-wet-upleasant-surprises.html
https://ls1tech.com/forums/appearance-detailing/80103-water-leak-back-seat-floor.html
https://ls1tech.com/forums/appearance-detailing/140716-interior-smells-flooded-carpet.html
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/192982-leaky-t-tops.html
