Easiest/Safest way to remove stock emblems
I want to replace my stock SS badges with some high polished ones and I'm sure there is more to it than simply pulling them off, exactly what though?
and any sources for some nice badges would be appreciated...
Originally Posted by Zymosis
A bit off topic but how do you attatch the retro 69 style emblems. I noticed that they have prong type of things on the back that slide into older style cars. Any suggestions.
I cut the prongs of with a dremel and then grinded them flush. The also have a slight curve in them that you will have to straighten. I put it in a couple of towels and SLIGHTY tapped it. Whenever you attach the emblems to the car be sure to puch A LOT of masking tape over it to hold it in place for about 24 hours. I learned that the hard way, But it all turned out good.
Originally Posted by az28vance
I would grind the "prongs" off and then use a emblem adhesive to attach them to the car.
For emblem adhesive would 3m work? or is there something else more applicaiton specific i should get
Thats what I figured, I just wanted to make sure there wasn't a 'prongless' version I was missing out on.
3M makes a couple emblem adhesives. There is the type in the tube(part number 8061?) and then there is the type that is press in place (8069?). I don't have my work stuff with me, but I'll search on 3M's site and see if I can find it.
http://products3.3m.com/catalog/us/e...er/output_html
