Cloudy Shifter Plastic
The piece of plastic that covers the P R N D 3 2 1 has gotten like cloudy, to the point that in daylight it is next to impossible to tell what gear I am in by just looking. Any ideas as to how to clean this or replace it? Thanks.
BTW I have an 01 T/A A4.
If you have a Ace Hardware close to you they sell a plastic polish that will make it clear again. if not try http://www.eastwoodco.com/ they have it
OK the suggestions above didn't work, I got a plastic polish from a local hardware store, and it did nothing. Now I have some pictures of the problem. Could I just replace the piece? I saw a car one time that had it replaced, with a plate that read T R A N S Am down. This is quite annoying, what can I do about it? Thanks.
http://i2.photobucket.com/albums/y43...r/DSC00170.jpg
http://i2.photobucket.com/albums/y43...r/DSC00171.jpg
Originally Posted by PSYKOZ28
I would look into a DIY peice, maybe come clear plastic from Lowes and cut to fit, dont see why that wouldnt work.
Im assuming once you unscrew everything around the console and slowly wiggle and oh yeah...take off the shifter ***, it should come right out. If it doesnt your wiggling will help ya find any screws you forgot. Maybe using some of that polish on the other side will work? If not, I'd try what PSYKO suggested. Good luck!
Thanks for the suggestions. I will take it apart tomorrow, and see what I can come up, it looks like I am going to do some kind of custom piece. I'll will post up my result afterwards.
Hopefully it goes well
Did you polish only the top side because that fog looks like it's from the underside?
Anyway just take the shift plate off and there are some 7mm bolts on the bottom that hold that piece amoung others on. you are more than likely gonna need a dremel (if you don't have one) to make that piece out of plexiglass.
