Best swirl and stratch remover by hand
Nothing will repair swirls or scratches by hand. Waxes and glaze will only temporarily hide them.
Find someone that can use a polisher/buffer with a fine compound, the 3M perfect it 3 is a great product for removing small blemishes or imperfections.
Then use a foam polishing pad to remove any swirls that the compound might have left behind.
Then wax it to protect your work.
Originally Posted by Flawless
Unless you are superman, you will not be able to remove swirl marks by hand.
Be aware you cannot get a swirl free finish whether your doing it by hand or machine. You will have better results w/ a machine i.e porter cable or a rotory (experiences users only). good luck
