Sponsored by: DashLynx
Progress pics of my tailpanel
Old 02-06-2005, 01:57 AM
RaNsOm's Avatar
Default Progress pics of my tailpanel
So I finally got around to taking it off today since it reached over 32* outside. I had always wanted to paint it satin black like the berger camaros, and I have a large '69 Z/28 emblem that I wanted to put right in the center, so Im trying my hand at a little body work. I used 400grit sandpaper on the whole panel, inside the letters, and on top. I did about 3 layers of bondo, letting each layer dry completely before applying the next. 4th time around I just spotted bondo wherever there looked like it needed some. Then I sanded it down with 320 grit till it was smooth and flush with the rest of the panel. Tomorrow I start the primer and painting process. more pics to come.
Old 02-06-2005, 04:39 AM
JackZ28's Avatar
Looks good so far. Can't wait to see the final product.
Old 02-06-2005, 06:58 AM
DopeFedZ's Avatar
Great job. I did the same thing with mine I just haven't painted it yet
Old 02-06-2005, 09:08 AM
BTLFEDSS's Avatar
Nice to see people trying new stuff
BTLFEDSS
Old 02-06-2005, 06:56 PM
ArcticZee's Avatar
I just got mine back on my car, I also filled in the key hole. I think it looks pretty good.
Old 02-06-2005, 07:46 PM
superchannelkev's Avatar
did the key hole too just waiting to paint it
Old 02-06-2005, 10:45 PM
RaNsOm's Avatar
Pics of the 'almost' finished product. I still need to go over the CAMARO one more time with some bondo, resand it, primer and paint it. Nobody told me body work took this much patience, lol
Old 02-06-2005, 11:10 PM
Z95m6's Avatar
maybe some of you guys that know body work can answer this. How do you fix filled holes from showing through when you paint them black. I filled in the Corvette letters on my FRC's and then i block sanded and painted it with filler primer. I then block sanded them again and put another layer of filler primer on. When i was done with that you could see any of the Corvette letters. I then painted it with Flat black. When they dried if i turned them the right way you could see the old out line of the Corvette letters. I've also seen people with cars that have been repainted and you could see where work had been done on the piece thats been painted black but the surface was smooth. Its like you could see through the paint in a way but the surface was smooth. Its only that way when you look at the piece at the right angle with the right light. Any suggestions. I'm wondering if that is why Ransom is redoing his.
Old 02-06-2005, 11:14 PM
CULATR's Avatar
RaNsOm LOOKS SWEEEEET ....
Old 02-07-2005, 12:06 AM
JxxxOxxxE's Avatar
So what are you painting this with? Just some spray paint or what?
Old 02-07-2005, 08:02 AM
RaNsOm's Avatar
yeah, any paint at Advanced Auto or any parts store. Personally im using Low Gloss Black engine enamel for the final black coat, and black primer underneath.
Old 02-07-2005, 08:07 AM
Assassin's Avatar
Z95M6... it could be from improper color fill, not enough black or your primer was not intended for that type of surface, get the right primer sanded smooth and make sure to use alot of color...
Old 02-07-2005, 02:49 PM
BitViper's Avatar
Huh.I ever would have thought that that piece could come off....wheres it connected?
Im actually pconsidering using Vinal to cover that palel up....pry off th eZ28 and bowtie....apply vinal...re apply emblems...go drinkin!
Old 02-07-2005, 03:37 PM
RaNsOm's Avatar
bitviper- open your hatch, lift up the carpet covering the rear portion. You'll see 4 10mm nut/washers, and 4 little plastic things. Twist the 4 plastic pieces to remove the taillights, and the 4 10mm nuts and the whole panel just comes right off.
Old 02-07-2005, 05:27 PM
JasonWW's Avatar
What is that panel made from? ABS, fiberglass or what? I wouldn't have thought regular bondo would stick to it.
Old 02-07-2005, 06:01 PM
Scotty-Z's Avatar
Looks great! Man I really need to do mine....
Old 02-07-2005, 06:21 PM
2FAST4U's Avatar
Here is a little idea of what it will look like!
http://community.webshots.com/photo/...65333491MkjYjy
Quick Reply: Progress pics of my tailpanel
