Headlights getting that funky frosty look.
My headlights are getting that funky look to them, they are starting to go from clear to frosty colored. Its on the outside of the lenes, it looks like there are a thousand little stress cracks in them. Is there any sort of polish I could use to restore them? Or would I be waisting my time and just save up for some new headlights?
Here is one link that i've found for ya.
https://ls1tech.com/forums/showthrea...lish+headlight
Here's the writeup that I did, mine were in terrible condition:
https://ls1tech.com/forums/showthrea...llow+headlight
Yeah, that should work... I removed my headlights from the car and took them to the kitchen sink since I had so much sanding to do. I kept a slow trickle of water going during the sanding. Mine were in TERRIBLE shape though...
So all the grime and filmy **** is outside the lite? What I'm askin is did you have to polish the inside of the lite at all? Are the lights pretty sealed, I want to do this especially if all you have to hit is the outside.. My lights look exactly like the pic you posted LS1sounds.....Be nice to get them clean again.
All of the work that I did was to the outside of the light. The lights are sealed with something similar to black RTV, you can get them open by baking in an oven at low temp for a little while to soften the seal. Carefully pry them apart with a butter knife or something if you need to get inside for cleaning or doing the smoked headlight mod or something.
Thanks
Originally Posted by pailheadz28
LS1Sounds, we had chatted a while ago about this same subject, well I'm just now getting around to doing it. Let me ask you, I started wetsanding with 800grit and I've noticed the light getting worse than before, should this happen? Should it look a bit worse before it gets better? I stopped cause I didn't want to make my light even worse.
Thanks
Thanks
The left half is untouched, the right half is sanded with 400 grit:
I think this was after sanding with 1,500 grit:
The left half is sanded with 1,500 grit, the right half is after the roughest of the 3 polishes:
Final product after all 3 steps of polishing:
those look great man, i need to do mine sometime, i got all the sandpaper, now i just need the polishes. nice work and write-up, thanks!
edit: i didnt know the polish was that cheap, ordered mine. i think it was $15 shipped. i spent more than that trying other stuff that hasnt worked.
If you want to do it real easy.....put some sort of polish on them that you would use to buff the car, speed glaze of some sort....
Use a buffer, and thats it.....takes 20 seconds a piece.....
Originally Posted by 2000Z28M6
lol i thought that was kinda funny....you start tryin to sand and it looks like ***.....Kinda makes you wonder if your doin something wrong... But the final pictures are worth it... I would of wondered the same thing this weekend had he not said something.
Gonna get back on it this weekend....
