Musty smell only after driving?
My LS1 Camaro has a musty smell that gets worse when I drive the car. I can let the car sit in the garage with the windows down and spray Frebreeze and other odor killers in it and it will start to smell decent again in a few days. Then I take it for a drive the musty smell returns. I have never ran the A/C while driving -- only the heater since it is winter. I do not smell anything coming out of the heating vents. Every thing in the cloth interior is dry. It has not been in the rain for months (at least). What could be causing this musty smell??
Would a leaking heating core wet the carpet and make it smell musty (but not like coolant)? Where is the heater core so I can check the carpet near it?
Thanks,
Fred
Thanks,
Fred
barf!
damn that sucks, my cousin's car had this rotten stink smell. he ran over some road kill and some crap got on his exhaust. so when he would run the car it would smell
Well, the smell is not burning flesh or trash. It doesn't smell like dead rodent either (i've experienced plenty of those in the house walls!). It is a slightly acrid, moldy smell that comes out after driving the car for a little bit. The longer the drive, the worse the smell gets. Nothing bad while the windows are down, but it can accumulate and get fairly "dense". I can clear the smell out once the car is parked by using Frebreeze and keeping the windows down, but I need to find the source.
The car has full stock exhaust including the cats -- the exhaust doesn't smell bad or rich. The rear of the car is odorless. The strongest smell seems to be around the passenger seat.
On a side note, I did check to see if the A/C condensor drain was plugged, and the hole I found (on the passenger-side of the engine bay, at the bottom of the black box that the A/C lines go into as seen while lying under the car on ramps) was not clogged at all.
I think I know what you're talking about. Sometimes mold builds up in the A/C because of moisture, and causes it to smell even if you don't run the A/C. My truck has started to do that too. It's smells brand new when I get in, but after I start driving for a bit, it starts to smell.
it has happen to me aswell, this time i was driving and it seemed like the smell was coming from the bottom where the vents are at... i dunno kinda weird. sucks when i have a babe and it smells like that.
I'd guess you have bad cats maybe? The bump in the floor on the pass side is a cat so.....
Edit: altho I think bad cats smell like rotten eggs, I wouldn't know though..
Check your coolant level if it's low it might just be your heater core. After you drive it for awhile the core heats up and makes the musty smell more apparent. Maybe?
Any instructions on how to look in or get to the heating/cooling vents to clean them out? Spraying stuff down the vents doesn't work well, does it?
Thanks,
Fred
Thanks,
Fred
smelly...
It happened to me too..... It ended up being the rear hatch was not sealing well. never drove the car in the rain in would just get in from washing or the humid weather... The reason why mine smelled the more i drove was because the exhaust would heat the carpet and make it smell like 20 yr old gym sock....
just open the hatch and pull out the carpet and let it dry.... then get the hatch adjusted...
not sure if that's you problem but that's what happened to me...
hope I helped
chris
hope I helped
chris
It is your heater core. This exact thing happened to my 1996 Camaro. I thought it smelled like fishsticks of all things and coolant leaked all over my passenger side carpet. The liquid is a orange/red color, is sticky, and smells really bad. GET IT FIXED NOW!! I procrastinated and ended up paying over $2000 to have my entire coolant system replaced .
One day I went to work and as I drove a terrible smell kept getting worse, ended up the next door cat sprayed in my cowl. Had to use industrial odor remover to get the smell to go away.
