Halos and Smoked Clear Corners DONE !!!! :)
here are the before and after pics,
I just need to wire up the halo wires to the parking lights, I didnt have the right tools and well it started to get cold ova here....hopefully I can hit them up next weekend.......
thanks guys/gals , I got them off Ebay for $36.00, and that included shipping. It's funny I saw a post from another member in here, asked him where he got them from, he told me I bought them
If you guys want more info, just let me know and I'll PM you or something witht he info...
The HALOS, my girl bought them for me for X-MAS, and finally had a nice day to get them on....
If you haven't already, I suggest wiring the Halos to a switch. I picked up an extra fog light switch and hooked mine up to it and works perfectly!
Also, on a side note, what was the members name from eBay where you picked up the corners?
To a switch huh, I may consider that then......
And as for the ebay seller, I will look it up and post back or PM you.
John
John
John,
No worries about the corners, I picked some up from 4caroption.com for $31 shipped.
As for the halos to a fog switch, if you already have a fog switch, simply get another one and use wire taps to tap into the same wires on your current switch, except the YELLOW and BROWN. You need to hook up the power wires from the halos to the YELLOW, and a switched source to the BROWN (or you can simply splice into the brown from the current fog switch, but then halos will only come on like the fog lights, when the headlight switch is in the ON position). Really simple, quick and clean install! Here's the info for the wiring of the fog switch harness in case you need it...
A - Light Green - ground for the ON indicator lamp
B - Black - ground for the switch illumination
C - Gray - power from the headlights for switch illumination
D - not used
E - Brown - power input for the fog lights (connect this to ignition source for your accessory)
F - Yellow - power output for the fog lights (connect this to a relay or to your accessory if it doesn't draw much power
D - not used
Originally Posted by LS1Zedder
How do those Halo's work? It there a bulb inside the center hole? Is it just a ring or does light come out as well?
Originally Posted by juicedSS
dang those halo`s are sweet could you hook up a switch for em where my traction control switch is supposed to be
Two fog switches...first one is for halos, second one is for fogs. Then the ASR switch, then a dummy switch (does nothing, basically blank).
Very easy to wire up...
