Pics of the Formula
Pics of the Formula
here are some pics....
some pics of the engine bay, and a try at getting a pic of the slightly ported intake port on one of the heads (didn't work out too well though) notice it is also coated in oil
777. Sweet looking car man my advice change your lid to lower box with TSP air box, my friend was had same your lid after he change it to lower box the car get very well also more 7 rwhp
Any sound clip or vids??
Possible Scammer - Buyer Beware - Issues Unresolved
Originally Posted by 777
no sound clips or vids...the hood is not setup to run with a standard lid system...so i don't know how your friend did it if he has the same hood as me
i have tested a little with cleaning up the engine bay...i just don't know what products to use really...i got some engine degreaser but it didn't really do much...anyhow the rear tires are 315.35.17 sumitumo htrz's...don't know if i'll buy again they have a 10" contact patch...so do my 275's up front they seem to be getting better traction now that i have put a few miles on them...so we will see since they are cheap ~300-350 mounted and balanced
hey, since you have a formy with the prokit...how bad do you scrape, if at all? do you have to be extra careful or anything? i was thinking about picking up a prokit, but i wasnt sure about the duals scraping..
duals don't scrape hardly at all...the front end plastic piece under the car scrapes more than the duals...i have scrapped going reverse out of my driveway pretty fast...but it left about a 2" long mark...i wouldn't worry about it...if you are somewhat carefull you have nothing to worry about...i go over speed bumps slow not because of the exhaust but because the front end of my car...i'd say go for it...i have no problems...it may take a little to get used to...but if you travel the same roads almost everyday then you will know where to be careful...like big rail road tracks...haha...i don't think the duals would be worse than any cat-back ory setup...
if it were a standard trans am hood i would have...i wish i had a camera to show you the underside of the hood...it has a square cut out of it and the filter system tucks up into the hood...
I know about that. my friend have same your hood from underside but he change it to lower box believe me the lower box much better than your box. if you want to make sure i have pics.
