going to get more pics how to add
looks nice, id probably do the rest of the body kit just so that the lines match up, some halos and clear corners, could you send me a pm with more info on where you got your wheels and and an approximate price, thats a 17 in the front right? Thanks and good luck
A little tip for you. Your front fenders arent supposed to be bowed out like that by the doors. Get under the car and you will see that the pinch where the fender bolts to the car is probably all bent to hell. Id unbolt the fender and bend that weld straight then bolt her back up and it wont be sticking out like that.
Other than that car looks good. Could use a nice 3m buffing to remove some of the swirls.
