Sponsored by: DashLynx
Which power antenna is the correct one?
Old 04-12-2005, 07:43 PM
Z95m6's Avatar
Default Which power antenna is the correct one?
My girlfriend bought me a TA/firebird power antenna off ebay. It looks just like this one. http://cgi.ebay.com/ebaymotors/ws/e...sspagename=WDVW
Here is one pictured in a install page. Its installed in a Camaro
http://www.blackcamaro.com/images/antennadone.jpg
You can't really see the motor but the bracket is definitely different than the one pictured in the first link on ebay. I've seen two different part numbers listed. I'm trying to figure out which one is right. The one i have is 10402860. Which one is correct? Also if the first one is right where does it mount to?
Old 04-13-2005, 11:36 AM
Z95m6's Avatar
None of you TA guys can go out and look for me?
Old 04-13-2005, 09:32 PM
ACW
ACW's Avatar
GM part numbers for the Firebird power antennas:
10269280 = 1993-1996, some 1997s
10402860 = 1998-2002, some 1997s
Old 04-13-2005, 09:53 PM
Z95m6's Avatar
OK thanks does anyone have a pic of where the 98+ power antenna bolts to? I cant see where it should bolt.
Old 04-13-2005, 10:04 PM
1BadMoFo's Avatar
hey, I have a very detailed list of instructions that I can email to you, including part numbers for a manual switch etc...what is your email addy?
Old 04-13-2005, 10:09 PM
ACW
ACW's Avatar
Why not post it here so it's available for future reference?
Old 04-13-2005, 10:55 PM
Z95m6's Avatar
cj428mach@yahoo.com. I've seen two install guides but none have pics of where exactly the 98+ antenna bolts too. I don't see any place it can.
Old 04-14-2005, 10:57 AM
1BadMoFo's Avatar
sending now.
Old 04-14-2005, 10:59 AM
1BadMoFo's Avatar
good point, I'll see what I can do...I know it had alot of hand written wiring diagrams that I'll need to scan somehow, the rest of GM part numbers for the items, including the switch if desired, new face plate etc...
Old 04-14-2005, 11:01 AM
1BadMoFo's Avatar
Order as follows from www.gmpartsdirect.com :
1 GM Part number for the antenna is 10402859
1 lighter adapter 12117322
1 convertible top switch P/N 10402722
1 convertible switch plate P/N 10280510
1 switch connecter 12125665
a 25 Pin D-Sub Female connector kit from Radio Shack
1' piece of 7/16" clear tubing from Home Depot
15' of 18 gauge wire (solid or stranded), and a butt-connector red or blue if you use 18 gauge wire
Old 04-14-2005, 12:30 PM
Z95m6's Avatar
sending now.
Thanks for sending me that. I got it but there were no working pictures with it. Basically all i need is a pic of where the 98+ power antenna mounts. I can't see a spot. I'm just wondering if you guys 98+ cars have a different bracket in there.
Quick Reply: Which power antenna is the correct one?
