Sponsored by: DashLynx
Shift Light
Old 07-28-2005, 10:26 PM
SmokinHot98's Avatar
Default Shift Light
I was wondering if I am able to hook up a shift light while using my stock tach. I think it would look better than adding another one? If so how would I go about hooking it up?
Old 07-28-2005, 10:32 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Yeah I just hooked one up the other week. I went with the raptor shift light, here is the website...http://www.raptorperformance.com/. Here are a bunch of pics as well/install procedure...http://www.raptorperformance.com/Che...let_camaro.htm. I hope that this is what you are talking about .
Old 07-28-2005, 11:20 PM
SSilverSSurfer's Avatar
yeha you can i use to have mine in the a-pillar where the little vent was at.
Old 07-28-2005, 11:33 PM
LS1_SS's Avatar
Same here, I have the raptor light.. I actually just finished putting it in..
Old 07-29-2005, 01:35 AM
BigSteele's Avatar
yeah I use the harlan with my stock tach. The stock tach lags a little but I think the actual signal from the PCM is pretty accurate (and therefore the shift light should be). I dont think an aftermarket tach is worth it, all you need is a shift light. Concentrate on driving and when you see the light, shift. thats the best setup IMO.
and personally big tachs on the dash look dumb unless your car is a drag car. I put my shift light in the AC vent, so you cant see its there untill it comes on.
Old 07-29-2005, 09:41 AM
JBIRD02's Avatar
yeah, its pretty easy, I've got my Autometer on my a-pillar w/ my gauges. You need to splice into the white #10 pin.
Old 07-30-2005, 01:23 AM
lferdzl's Avatar
anyone got a proper write up? or step by step process? this is cool. i didtn know you could use stock tach. this makes me even more interested just to get a shift light.
Old 07-30-2005, 12:53 PM
Lithium's Avatar
You can use this write up - http://www.installuniversity.com/ins...sity/index.htm. Or the write up the I posted about 6 posts up.
Old 07-30-2005, 01:03 PM
BLUE01's Avatar
I want a raptor shift light but have to spend money on my new hood.
Old 07-30-2005, 06:48 PM
liqour enthusiest
88monte's Avatar
i think you splice into a wire on your ecm, i saw the directions on installuniversity.com i believe.
Old 07-30-2005, 08:21 PM
Reject's Avatar
this would be a great mod, if only i had a M6 instead of a A4, owell it all good witha LS1 unda' tha hood!!
Quick Reply: Shift Light
