Sponsored by: DashLynx
red calipers
Old 08-04-2005, 11:33 PM
dark ls1's Avatar
Default red calipers
just wanting to know if any one has bought the cheap caliper paint kit from autozone do they look good or do they look like crap .
Old 08-04-2005, 11:40 PM
gkrocket's Avatar
You don't need a kit. Go here http://www.ls1howto.com/ and on the right side you'll see F-Body Howto's, go to #14. Thats how I did mine and they came out great. Good luck.
Old 08-04-2005, 11:48 PM
BLk01SS's Avatar
I've got one that I'm gonna use on a friend of mines car in the next few days. I'll let ya know how it turns out. I did mine with a kit from Tirerack. It turned out great. The Dupli-color kit looks like the same thing, so it should look pretty good.
Old 08-05-2005, 08:31 AM
99zee's Avatar
Just make sure the paint you use can take the heat. I used a caliper paint that was in rattle can.
Old 08-05-2005, 08:38 AM
Mark IXZD 150's Avatar
Plastikote caliper paint is the best, IMO. I found mine at Pep Boys. It dries fast, goes on smoothly and is the best color red I've seen. Also, if you want to add caliper decals, be sure to get the GM licensed ones from www.afterthoughtsauto.com
Old 08-05-2005, 09:14 AM
cthomas's Avatar
I used 1200 degree engine paint in a rattle can. Mine was done almost a year ago and still look like the day I painted them. However I hardly drive the car, but put atleast 2000 miles on it since I painted them.
Old 08-05-2005, 02:46 PM
hambone138's Avatar
Yeah, the rattle can works good get a good high temp enamel paint, make sure you clean the caliper good and mask it off well. but it looks great
Old 08-05-2005, 04:47 PM
Darkspoon's Avatar
If you're talkin bout the kit with the brush then ya I used it. Looked great for like 3 weeks...now it looks like ****. Next time im just getting powder coated ones!
Old 08-05-2005, 05:31 PM
LoudmouthLT1's Avatar
I used high temp engine paint and it came out good. It's all in the prep work, make those babys shine before you paint them and it will stick with 1 coat.
Quick Reply: red calipers
