Blacking out center taillight piece
I was just wondering if theres a special way to black it out, or do you have to buy a specailly made one? Like could i wet sand the red out and buiff it? That would be the back piece of a Trans Am tail light assembly.
i did mine yesterday. used fingernail polish to remove most of the red(pink), then used 1500grit wet sanded till all the lettering and bird off. then went with 2000grit wet. then i used mothers plastic polish and buffed it with my buffer. came out great. im not sure why i waited so long
one thing, though, make sure u do all the sanding u need to do before u do the polish. i tried to go back and sand some more and it added a ton of work cause the sanding didn't go well cause the water would bead off instead of lubricating and it did more scratching than good
