a few body questions
Okay ive pull my engine to do some work.So while it was out i got the idea to smooth all the welds and cracks in the engine bay to give it the more custom look my question is.Im using bondo hair,bondo glass and bondo when i put the all back together and pull 1.43 60 fts is it all gonna crack and bust loose?
Always take the paint off before you put any kind of bondo substance on it. Practice with the grinder and all you will need is high build primer. Be careful a weld is alot harder than the sheet metal (opps now you got a hole to weld up) Good luck if you have ???s ask a body man not an engine man
yes its sanded to bare metal and cleaned then applyed the hair i think ill prob just remove it all must of been one of those slow ideas it would of helped but oh well thats what chrome is for
You could carbon fiber it, then paint over the carbon fiber (I guess) and never have to worry. It would take a SHITLOAD of torque to crack that stuff. You'd probably end up twisting your unibody before you snapped some carbon fiber. It'd be an expensive project, but damn, can you imagine the visual impact that would have?
