how do you remove the door panels?
first take off the panel with your window and lock switches. Two retainer clips hold it in. Sometimes you can pull it off. You might need a small flat head to help.
Next, remove the two screws holding the surrounding trim piece. Once the trim piece is loose you will have to pop off the piece of plastic that slides back and forth whe you lock your doors. It pops right off the metal rod. You can either use some needle nose plyers or you fingers.
Then there is only 2 screws under the armrest. Once those are out, all you should really have to do is kinda wiggle it up and out.
