Sponsored by: DashLynx
sprayed glass cleaner on headlight lens now cloudy
Old 09-19-2005, 01:14 AM
AntiVenom06's Avatar
Default sprayed glass cleaner on headlight lens now cloudy
What will get this cloud out?
The glass cleaner just left a white cloud over the head light lense, I tried some plastic cleaner but that wouldn't remove it.
Old 09-19-2005, 01:20 AM
TUMBLRws6's Avatar
man sounds like it may have had bleach in it...hmmm...i donno if there is much you can do...what kinda window cleaner was it???
Old 09-19-2005, 02:50 AM
dont remember the name, is the any type of plastic polishing bit I can get ? Or a very good plastic polish?
Old 09-19-2005, 07:56 AM
Smith4046's Avatar
Think a company named Novus makes one. Try your favorite search engine and type in "Novus Plastic Cleaner and Scratch Removal Kit".
Best of luck.
Steve
Old 09-19-2005, 08:39 AM
LS1_Unleashed's Avatar
www.spadepot.com for the novus polishing kit. But before you try those, use some tire shine on them, I read it on another thread and tried on mine and it cleared them up. If you have oxidation and alot of haze(not due to the cleaner) then you will need to do some sanding along with polishing. I have also heard of people using brake cleaner, but I wouldnt recommend it until you try the tire shine. Lemme know if either of those works. Just spray on the tire shine and rub it in like you would a wax or something.
Old 09-19-2005, 04:38 PM
Ling_650vette's Avatar
There's a sticky in the top of this section that says "Fixed my cracked/yellow headlight" that'll have some of the information you're wanting about the sanding/polish method.
Old 09-19-2005, 04:44 PM
NOT-MEE's Avatar
This is what i have done in the past. Use nail polish remover the acetone type not a lot. Just wipe and go.
Quick Reply: sprayed glass cleaner on headlight lens now cloudy
