Sponsored by: DashLynx
Goo Gone or 3M Adhesive Remover
Old 11-22-2005, 10:45 PM
lrk322's Avatar
Default Goo Gone or 3M Adhesive Remover
I have to remove some 3M molding tape that was used for the body kit no longer on my car.
What would work better to remove it and still be paint safe? The Goo Gone I already have or 3M adhesive remover?
Thanks,
Lane
Old 11-23-2005, 06:34 AM
GM Muscle's Avatar
From my experiance there is really no comparison between the two. You can't beat the 3M Adhesive remover and the 3M paint cleaner. Is does say on the bottle that it can hurt the clear coat if you rub real hard but I have never had any problems using it yet.
Old 11-23-2005, 09:00 AM
NBM7278's Avatar
I know that they make a goo gone specifically for auto paint. I bought some to remove pin stripes. I think it comes in a little kit with a paint safe scraper.
Old 11-24-2005, 02:05 AM
lrk322's Avatar
alright, cool. Thanks for the helpful replys. away with you adhesive goo!
Old 11-24-2005, 02:07 AM
Brandon Boomhauer's Avatar
3m stuff rocks!
we used it exclusivly at the dealership i used to work for.
I loved that stuff.
Old 11-24-2005, 07:58 AM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
Agreed. I'd go with the 3M Adhesive Remover.
Old 11-24-2005, 01:24 PM
kTkz2800's Avatar
i took off my body moldings and it has the old stock double tape stuck on there use the same thing?
Old 11-24-2005, 04:56 PM
5550racing's Avatar
To remove double sided tape, pinstripes etc... you should get one of those pinstripe remover tools that go in a drill. like this one. this is a pneumatic one but you get the idea. theres nothing better than these if you have a lot of adhesive to remove or you will be doing it frequently. i've used the style that goes into a drill and it worked very well. if you use it wrong it will go thru the clear coat but its hard to do. 3m makes the tool also.
Old 11-25-2005, 07:49 PM
lrk322's Avatar
I got some 3m adhesive remover and it worked great. There was a spot that i rubbed too hard and took some clear off but other than that it saved me alot of time. Thanks for the replys!
Quick Reply: Goo Gone or 3M Adhesive Remover
