Stock Firehawk 11" Rims - 315's!!!
Sent my wheels off to get widened 2". Shipped them out on a Monday and recived them back two weeks later. Only bad part is I had no center caps. They overnighted them to me though. I used 1.25" Skulte adapters to kick the rims out far enough to clear the fender. I get zero rubbing inside or outside the fender! Just bolt up and drive basically. I did run around on a friend's chrome ZR1's for 2 weeks, but beats the hell outta running around on some old salad shooters (which I thought I'd be doing).
Thanks!!
Sent them to Wheels America. They cost $150 each if you have a donor rim, $200 if you don't. I didn't, but with shipping there (they pay return), tires, de-mounting/mounting, balancing and adapters it was $712. Yeah, I know on factory rims but for some reason I try to keep as stock looking as possible.
The tires are Sumitomo HTR Z's. At $110 a piece, they're cheaper than 275's!
These tires definitely hook better than the 275 Firestone Firehawks that were on there before. The tires are pretty soft rubber too, but only have a 160 tread wear rating. But at $110 each, makes changing alot easier to swallow.
Actually the place that did them also does shortening. I think that'd be freakin' SWEET looking.
Oh yeah the work done on the rims has a lifetime warranty too.
purple98haz28: Sorry I wasn't out last night. I should be tonight (Fri) though. Look for me!
