Hurst Short Stick Shifter...
I was wondering if I'm the only one who is doing this. The shifter is essentially the same Idea behind Lou's short stick, only not as short, but just a solid. They bolt straight to a T56 (If I remember correctly... ), and they eliminate teh rubber isloator that the stock shifter has that I absolutely HATE. Pic.
I feel like it will definetly give it a refreshing look compared to the stocker.
I will tell you all how it works once I'm home to re-install my PCM and figure out my clutch 'issue'.
Suggestions? Thoughts?
Hurst sells TONS of different chrome stick configurations. Go to their site and look them up. You can buy about any length and arch stick you want. The problem is they don't list measurements of the sticks so you can't tell what you need. I thought about swapping the black stick on my Billet Plus for a chrome one but don't know what length or bend I'd need.
awesome setup Arachnotron, i think i may just get that short stick and call it a day!
that stock stick on the right that comes on all t-56 fbodies regardless of hurst shifter or not right? it seems so.
