Sponsored by: DashLynx
Winter Storage, quick advice needed!
Old 01-04-2006, 09:17 PM
MetallicaMatt's Avatar
Default Winter Storage, quick advice needed!
hey everybody,
heres my problem in a nutshell
tiny garage, 2 cars
both fit, barely
right now the camaro is parked outside, TA is inside all torn apart b/c i'm finishing up my cam and nitrous install. But i have to leave for school in 2 days, so i wont finish
i really don't want to stop what i'm doing, push everything off to the side to put the camaro back in
the camaro is mint, spotless, babied
should i leave it outside????? i had it covered with my Cali Car cover and 2 tarps but all the rain lately has soaked through
so i would take the car cover off
or should i bite the bullet and try and get a storage unit for the rest of winter???
ohio winters -> very cold, snow, ice
Old 01-04-2006, 09:27 PM
neonblack's Avatar
Check out a marine (boats) store. They sell these bags that are intented to wrap your boat up in for the winter, but they work just as well for cars. My dad has wrapped up his 69 cuda for the past couple of winters with no problems.
Old 01-04-2006, 09:30 PM
how much $$?
neonblack's Avatar
To tell you the truth, I'm not really sure. I bet it would be cheaper than storage fees though.
Old 01-04-2006, 11:03 PM
hammerhead's Avatar
If you're going to leave it outside somewhere, I'd recommend a heavy duty cover that breathes- not a tarp. A tarp will trap in the moisture.
Old 01-04-2006, 11:15 PM
which means the boat cover is out...
Old 01-04-2006, 11:59 PM
bump for more responses
Old 01-05-2006, 01:10 AM
1SicV8's Avatar
keep it safe and get the storage unit, or put the camaro in the garage, take all the parts from the t/a and put them in storage, that way ur storage will be smaller and cheaper
Old 01-05-2006, 01:51 AM
blown 346's Avatar
I know I myself would put the Camaro in the garage, anything can happen to it while you are gone and its outside. I wouldnt want to take that risk, I would park it inside.
Old 01-05-2006, 07:07 AM
yeah thats what i figured, i just need to stop being a cheap ***
Old 01-05-2006, 08:18 AM
neonblack's Avatar
Heres a link to the car bag i was referring to...Car Bag
You throw moisture pouches in the bag to suck up any moisture. Unfortunately, the only one i could find was for indoor use. However, I know there are some outdoor ones available. I just couldnt find them online.
Or you could try this....car capsule
Old 01-05-2006, 08:44 AM
FastTrackDF82's Avatar
I always see DeLoreans in those inflatable ones at car shows.
Old 01-05-2006, 12:13 PM
i went ahead with the storage rental
rip off but at least the car is off my mind
Old 01-05-2006, 12:18 PM
TAbeba's Avatar
good choice! now u don't need to worry about it
Old 01-05-2006, 12:20 PM
since its in a storage unit now, should i keep the windows up or open? the dry winter air might help to keep the interior dry??
Old 01-05-2006, 02:16 PM
Charging TA's Avatar
Id probally keep the windows rolled up... I just moved from FL to Finland, and my TA spent over a month in a container coming over here, I left the window open because you had to climb in/out somehow... So when it finally got here there was some mold on the interior, most of it wiped right off though...
Quick Reply: Winter Storage, quick advice needed!
