Anyone familiar with 93-96 interior removal, inside please...
Does anyone know if the passenger side of the dash is removable from where it meets the gauge cluster to the A-pillar? I've removed visible bolts, but it still seems secured, as if it were glued down. I don't want to mess with it too much if it isn't meant to come out, and even though the fuse is pulled on the air-bag, it still makes me a little nervous mess in that area. Anyway, if it is removable, could anyone that's very familiar with it give a quick list of directions on how exactly it comes out?
The Dash isn't 2 pieces its just one. You need to remove the cluster, AC controls, then the kick panels also. Once you have the kick panels off you'll see there is a big nut on each side that holds the dash too.
Yeah its a pain in the *** to remove but if you want it done right its probably the way to do it. I wish i wasn't at college right now because i have my old 95 dash sitting up in the attic and i could look right at you and tell you exactly what it took to get it out.
Tell me about it! I have so many electronics in my dash it's not funny. The carPC alone has the USB wire running up to the top of my windshield for the USB GPS mouse, the audio wire that runs to my headunit, the power wire which runs to the battery, the ground, and a 12v switched source over on my fuse box. Not to mention my headunit which has 2 cat-5 ethernet cables running up to the top of my windshield as well when I had the faceplate to the headunit mounted in my sunvisor. And that's just the start! lol. I painted the dash last time while it was in car, just required a lot of taping off and a lot of newspaper to cover stuff, this time the only difference is how much sanding it'll take to get it 100% smooth before I paint it, although since the carpet is trash and being replaced as soon as I'm done with my interior panels, I really don't care if it get's dirty and covered in dust. Ah well, I'll try and remove it but if not I'll just do it the lazy way.
