Sponsored by: DashLynx
filling in the gap around the front TA license plate area
Old 01-25-2006, 09:43 AM
badmfkr's Avatar
Default filling in the gap around the front TA license plate area
can I use bondo in a tube (pre-mixed type) to fill in the gap around the TA front tag?
or do I have to use bumper rebuild plastic weld stuff?
I don't ever plan on have a front licence plate.
if I do this will the entire bumper need repainting or can it be airbrushed?
anyone have pics of this TA front bumper mod?
Thanks
Old 01-25-2006, 03:52 PM
FBodyPerformer's Avatar
never heard of this, but after I do the front bird I wouldnt mind filling that in either! Sounds like it would look awesome! thanks for the idea and hope someone can answer so I can look into doing it also
Old 01-26-2006, 10:16 AM
Cheatin' Chad's Avatar
Don't use Bondo.IT WILL CRACK,BREAK AND FALL OUT IN NO TIME. Get something called Duramix or an equivalent from your local auto paint jobber.
Old 01-26-2006, 12:01 PM
Phoenix 5.7's Avatar
ive seen this done on a v6 bird before. looked really clean. i will probably do this before too long if a reasonable way to do it is found. i live in a state with no front plate, and even if i were to move to a state with front plates, id keep the car registered here for emmissions and plate things. what kinds of retail places would carry duramix?
Old 01-26-2006, 07:41 PM
onyxxtreme's Avatar
I would grind the edges down on both the bumper and insert, fill in with a flexible epoxy, then smooth with flexible filler.
Autobody/paint supply shops sell everything you need
Old 01-26-2006, 08:01 PM
Ws6Extreme's Avatar
That Duramix stuff comes in such SMALL quantities.... An auto shop should have a better solution other than buying cases of that stuff. It looks like great stuff if you can get it in larger quantities.
Old 01-26-2006, 09:34 PM
Small? The smallest I could buy was the size of two caulk tubes. There's ALOT of it.
Old 01-26-2006, 11:15 PM
stryker14's Avatar
This will probably be my next project along with another slight modification to the front clip to give it a slightly different look. Here is a quick chop of the license area filled in.
Old 01-27-2006, 05:40 AM
richieg's Avatar
This man speaks the truth. I filled in mine 5 years ago almost verbatim what he said. Haven't had any problems with it.
Old 01-27-2006, 11:50 AM
Ws6Extreme's Avatar
The stuff that I was looking at on there said it was in 6 oz containers. Now I could have mis-read it, but that was my understanding.
Old 01-27-2006, 02:30 PM
LOHRTBT's Avatar
I have mine done...works fine..looks tons better.
www.cardomain.com/id/ramairdave
Old 01-28-2006, 10:55 AM
badmfkr's Avatar
Default tag
how much grinding is suggested on both tag insert & bumper?
is plactic weld bumper repair considered flexable filler?
I have a Bud that do'es only bumper repair contracting for Keystone said he would do it for $40. basically the cost of his glue.
BTW both cars look great.
Thanks
Quick Reply: filling in the gap around the front TA license plate area
