Has anyone switched their 93-97 firebird to look like a 98-02?
anyone do this?
Has anyone switched there 93-97 firebird to look like a 98-02? I mean switch the front clip and the wing, rear bumber and lights. If you have could you tell me what all you got into... And if it was bolt-on or more complicated stuff. Also can you put a 98-02 camaro gauge cluster into a 95 Trans am?
front clip is bolt on. once you strip the two cars down youll realize they look the same as far as bolts, brackets, and clips. the wing is no different unless you have a firebird. and im not sure about the cluster
