Triangle pieces between window and B pillar removal??
They are held on with double sided tape. You can just pry them off with a putty knife. Ther are quite thin, don't pry the roof panel by mistake.
New ones are like $3-$5 each. It is worth replacing them reather than dealing with cleaning up the tape and re-using them.
Good Luck!!
Good Luck!!
The drivers side has some scratches like someone took a dry paper towel and wiped something off. I found a brand new set on ebay for $20 so I'm just going to put brand new ones on.
Also because I cant stand it when small, inexpensive, easily replacable things are messed up.
Originally Posted by Red99TA
I just bought these last week from GMPartsDirect...it's funny that one's like $5 and the other was like $3.50. Where can I get strong double sided tape?
Do you have them yet?
The tape should be on there!
10240165, 10240164.
Not sure which side is which. You can check these #'s on gmpartdirct.com
Good Luck!
Good Luck!
