Polished Calipers
Old 02-13-2006, 11:18 PM
Lucas'02SS's Avatar
Default Polished Calipers
My friend and I are wanting to polish our brake calipers, which will give it that shiny, chrome look. Have any of you done this or seen it done?
Old 02-14-2006, 01:22 AM
dimasZ28's Avatar
I did. here are some pics.
Old 02-14-2006, 03:43 AM
Lucas'02SS's Avatar
Looks great. Did you use a drimmel tool or a dye grinder (not sure on spelling of either of those)? And also, did you clear coat them?
Old 02-14-2006, 08:36 AM
~JOSHUA's Avatar
I'm going to start on "Project Brakes" when the weather is Ok for a T-shirt.
I don't know if I should do the whole caliper or just the flat part that you'll see through the wheel. I'll do the flat part and some of the wrap-around, but I don't think it's worth doing the whole freakin' thing that nobody can see unless the rim is off. Maybe I'm getting lazy.
Old 02-14-2006, 01:37 PM
sp00rkz's Avatar
wow, those look beautiful. And please do elaborate on how you did it
Old 02-14-2006, 03:08 PM
Lucas'02SS's Avatar
yeah they do look really good. What did you use to polish them? I am starting on mine on Sat.
Old 02-14-2006, 03:55 PM
98a4z28-410rwhp's Avatar
i havent done it but im guesing he wet sanded it up to like 1800 ish then went to work with a poligh wheel and some compound. thats what i would do, maby i would start with some brake parts cleaner before the wet sanding
Old 02-14-2006, 04:40 PM
93Hawk's Avatar
guide for polishing.... http://formula.bambeezer.com/calipers.htm check it out, tells you everything you need to know about polishing your calipers
Old 02-14-2006, 04:48 PM
H8 LUZN's Avatar
Ha! I knew you'd slip up sooner or later!
My polishing excursion has slowed to nearly nothing because its so COLD!! But when it gets warm again, i may be starting on that project as well.
Old 02-14-2006, 05:17 PM
Z28-CTYHNTR's Avatar
I bought everything I need to do this project, Im just kind of lazy and dont feel like jacking up my car, removing the wheel, taping off the area, sanding, grinding, sanding,... etc
Old 02-14-2006, 05:20 PM
steveo346's Avatar
This Is Like A Really Bad Repost....i Told Everyone A While Back How To Polish Calipers Like In 04 Or 05'....do A Search
Old 02-14-2006, 05:30 PM
You're obviously not new around here, so you should know "Really Bad Reposts" happen about every 10 minutes in the forum. Halos? "Tripple" Gauge Pods? Billet Grille? Berger Panel? Come on now.
Old 02-14-2006, 06:31 PM
LvDemKings's Avatar
steveo346 is Offline:
More likely 2005...
Old 02-14-2006, 11:56 PM
Lucas'02SS's Avatar
Okay, so I know how to polish the calipers. But do you think that I should clear coat them?
Old 02-15-2006, 05:05 PM
dimasZ28's Avatar
Thanks for the complements! I used the above link and went to town. It's not too bad, just time consuming. I did use a dremel with 80 grit at first to remove all the bumps and stuff. then used a sanding block to about 300 grit. I didn't use higher grit cause I got impatient. I polished with my dremel and a little mothers polish. came out ok. My advise is to be patient. Let us know how it turns out man! Oh and I didn't clear them...yet.
Old 02-15-2006, 05:26 PM
'Trust''s Avatar
Explain to me how you expected him to know that if he joined in 06? A simple search comment would have been enough
Old 02-16-2006, 02:41 PM
Lucas'02SS's Avatar
Thanks Reza. I wasn't going to say anything to him, but it was kind of a dick thing to say. If people didn't re-post things on here everyday, no one would have anything to talk about. You would just come on and search everything and leave. Not trying to be rude...but you gotta cut some people some slack.
The polishing is on for Sat. I'll post some pics and let you know how they turn out.
Old 02-18-2006, 10:58 AM
MetallicaMatt's Avatar
how much time did you guys spend on each caliper?
did you polish the bracket also, or should that just be painted? I'm down on co-op and only make it home every 3 weeks or so, i'm thinking about taking off all my brakes and bringing them back with me so i have something to do after work lol
my roomate will think i'm nuts
Old 02-19-2006, 07:53 PM
Lucas'02SS's Avatar
We ended up not being able to polish them yesterday. It freaking ended up snowing and the roads got all icy. So hopefully I can polish them next Sat.
I think that you can polish the bracket, but it would suck to do.
Old 02-20-2006, 08:29 AM
~JOSHUA's Avatar
You can't polish the bracket, it wil rust. You'll need to paint/anodize/chrome the bracket.
When I do mine I probably won't clear it. Just maintain it every two months.
Quick Reply: Polished Calipers
