Stock 4th Gen. Camaro Grille Removal?
Old 02-15-2006, 05:16 PM
sunsetta's Avatar
Default Stock 4th Gen. Camaro Grille Removal?
I need tips on how to get the old grille out without damaging the front nose. The Service Manual says to remove the nose, but I know that's not necessary. Help please.
Old 02-15-2006, 05:18 PM
ND4SPD _SS's Avatar
just pull on it. it will pop off. at least mine did.
Old 02-15-2006, 06:14 PM
camaroextra's Avatar
Just tie it to something stationary (truck, house), put it in reverse, and floor it
Old 02-15-2006, 06:17 PM
popocamaro2's Avatar
just yank on it you should be fine both of mine came off by doing so, it appears it should not pull off but it will
Old 02-15-2006, 06:18 PM
Tech Resident
WhiteKnightZ28's Avatar
Its a PITA but it will just pull off.
Old 02-15-2006, 08:04 PM
parbreak's Avatar
Grip it and rip it. That's what I did. No damage.
Old 02-15-2006, 08:21 PM
MannyZ28's Avatar
I used a golf cart and some rope. Hooked it up....floored the golf cart....presto! 2 seconds and it was done.
Old 02-18-2006, 10:59 AM
2_wacko's Avatar
Maybe I will tie mine to my atv and go.
Old 02-18-2006, 11:02 AM
2_wacko's Avatar
If I rip it off will it do any damage to the styrofoam?
Old 02-18-2006, 11:14 AM
MannyZ28's Avatar
Only one way to find out.....
I know some people go through the trouble of snipping the plastic taps off from behind, but most just rip it off. So whether you yank on it with your hands, or a ATV, it really shouldn't make a difference, just don't go crazy pulling it. Hint: If you drag the car by the grille behind your ATV....slow down and try again!
Manny
Old 02-18-2006, 12:28 PM
blown 346's Avatar
It wont damage the foam, I just do one side at a time, it takes some force to get it off so dont be scared to put muscle into it.
Old 02-18-2006, 12:35 PM
99camarosupersport's Avatar
i had some sharp *** snipper thingys and pulled it off, when i could see the tab, i just cut as close as i could and got it off and pushed the screw down in the hole, good nuff for me i didnt wanna rip it off it looked like that cheap *** plastic was flexing alot
Old 02-18-2006, 12:39 PM
Lucas'02SS's Avatar
When I pulled mine off, I held the bumper down firmly in the area I was pulling on, and just worked my way around. Don't be afraid to put some muscle in it, but if you are scared of messing something up, just put some pressure on the surrounding areas like I did.
Old 02-18-2006, 12:41 PM
Guy2626c's Avatar
be careful though, the bottom snaps out real easy. The top has "plastic nuts" holding it on. I just pulled until they popped. But i could tell if i pulled much more the paint would have started to crack.
Old 02-18-2006, 04:34 PM
Ling_650vette's Avatar
Its easy as hell. You shouldnt damage anything if you yank it off.
Pull the sides off, then do the bottom. Work from the outside to the inside. Then do the top. This will be the hardest part. Again, work from the outside to the inside. Should take you all of 2 minutes.
Old 02-18-2006, 06:24 PM
2_wacko's Avatar
So when installing a billet grille you mount it to the styrafoam?
Quick Reply: Stock 4th Gen. Camaro Grille Removal?
