Taking off Rear panel decals
Alright, sorry if this is a stupid question. But, whats the best way to get rid of the Trans Am rear panel decal? Mine is fading, but the bird is fine. I just want to take the lettering off without screwing anything up......thanks in advance for any advice!
Remove the center panel first, then
Take the decals off with acetone/nail polish remover
sand with 1500 grit wet/dry paper
move up to 2000 grit
polish with plastic polish
Replace decals with your choice of color, or leave blank
If the search is working, search for center panel, or trans am rear panel
It's made of plastic, and yes the sanding will scratch the surface, but you can get it back to being unscratched, if you just want to remove the decals and not polish it, just use the acetone
EDIT:
Search is up, found this thread with instructions
https://ls1tech.com/forums/showthrea...ght=ceta+panel
Last post
EDIT:
Last post
