T-Top Weather Stripping Detailing
Old 03-29-2006, 12:18 AM
slayer_taunu's Avatar
Default T-Top Weather Stripping Detailing
(tried searching for this, but no luck)
what is the proper way to maintain the weather stripping for the t-tops and side windows? is something like armor all good enough? or do i need to take it up a notch with something special?
Old 03-29-2006, 08:53 AM
bboyferal's Avatar
For all weather stripping, use silicone grease.
Old 03-29-2006, 09:06 AM
68ss_00ss_87_95's Avatar
i use white lithium grease.....just make sure you dont put too much on or it leaves a white residue
Old 03-29-2006, 09:45 AM
Dal1as's Avatar
Dielectric grease. Wipe it on with your finger. A few days later after it's absorbed a bit. Remove excess with a rag. Do not do where the window is going to touch though. Dielectric grease is also good for in the front channel for the side window. Lasts much longer than silicone which will eventually wash away.
Old 03-29-2006, 04:41 PM
Droopy8503's Avatar
can u buy dielectric grease at autozone or something??
Old 03-29-2006, 06:02 PM
Shallow Bay's Avatar
Yeah, I just picked up a small can of that stuff the other day from Autozone.
Old 03-29-2006, 06:23 PM
JonB's Avatar
dielectric grease is what i use as well.
Old 03-29-2006, 06:51 PM
formerly mystic-t/a (changed 02/05/2013)
ThatGuySkye's Avatar
Yes, something like Armor All or another water based dressing would work. Never tried grease, but I wouldn't ever want to either.
Old 03-29-2006, 07:18 PM
PontiacFan's Avatar
GM part #12345579, Dielectric Silicone Grease, 1fl.oz. tube
Usually runs about $8-10 depending on your dealer.
Old 03-29-2006, 07:29 PM
AncientRgn's Avatar
I use tire dressing
Old 03-30-2006, 07:32 PM
ok, 5 different answers... not exactly the answer i wanted
Old 03-30-2006, 07:42 PM
Viper's Avatar
Try searching the net, you'll find 20 more answers. Weather stripping is weather stripping, regardless of car.
http://forums.roadfly.com/forums/det...5405529&page=1
Quick Reply: T-Top Weather Stripping Detailing
