Sponsored by: DashLynx
LT1 Tail-light conversion for an LS1......
Old 03-30-2006, 03:20 PM
CamaroSS01SLP's Avatar
Default LT1 Tail-light conversion for an LS1......
Does anybody have some type of write-up or instructions on how to make the LT1 tailights fit an 98'+ camaro & have the lights work just like the LT1 cars to where the whole red panel lights up?......
Old 03-30-2006, 04:25 PM
Ttt.........anyone ????????......
Old 03-30-2006, 10:27 PM
Camarokidd24's Avatar
I don't have a write up but can help. I just did a set with my buddy on his LS1 car. He got some LT1 fitted lights with a black background and we made them work.
We took a dremel to the back of the tailights to cut off the tabs that hold the bulbs inplace, then just hot glued the bulb casings in without the tabs.
The lights almost fit but there is forward dent in the metal where the main brake bulb housing sits. To fix this we took a drill with a 1/4 " bit and pulled back the carpet from the inside t-top well. Drill from inside to out (that way the bit doesn't move around it sits into the crease). The metal is to think to beat in without the hole so drill first (just trust me) and then use a hammer and taper the bump back a little.
The taillight should now fit fine and put the carpet back into position and noone will ever know you drilled a few holes in your car!
Old 03-31-2006, 12:05 AM
WsSickLs6's Avatar
Wow...ok Camaro...
If you were doing LT1 TA tails i'd drive to texas and whack you with them...
Old 03-31-2006, 12:14 AM
Z28-CTYHNTR's Avatar
Im thinking of doing this too, to replace my melted *** stockers. I really wish we had more options for tail lights.
Old 03-31-2006, 05:43 AM
pontiacfireTAWS6's Avatar
anyone want to trade????????? I have LT1 tailights, id like to go to 98+ style..
Old 03-31-2006, 07:07 PM
TTT.........Thanks alot Camarokidd24, any wiring info ??????......
Old 03-31-2006, 09:47 PM
Originally Posted by WsSickLs6
Wow...ok Camaro...
You would whack me with them?? I'm in Florida, he's in texas
wires are actually the same, just the bulbs don't fit in the stock housing without a little persuation (sp). just use the dremel and then hot glue. The only way I know you could rewire them is how I did on my old LT1 and that is to have the blinker run from inside out. it flashes through the bulbs, like in a series. it's kinda hard to explain and I didn't really care for the look when I was done.
Old 03-31-2006, 10:35 PM
quiet_storm98's Avatar
why dont you guys just paint the amber part of the tailights red with some translucent paint..thats what i just did and it looks much better and actually is red when it blinks
Old 04-01-2006, 01:16 AM
brynnda's Avatar
me too, ill give up my lt1's for ls1's
Old 04-04-2006, 01:06 PM
SHINER's Avatar
who the hell would put LT1's on an LS1??? Then people are gonna think u have an LT1 and u just put a LS1 front clip on...
Old 04-04-2006, 01:43 PM
'Trust''s Avatar
Imports look better IMO. Or just get rid of the amber part in the LS1 lights. The LT1 lights seem to have bad seperation and lines of the light (you know what I mean) where as the LS1/Imports are more defined (I'm NOT talking about Altezza's!)
Old 04-04-2006, 06:32 PM
I agree..i also dont like how the whole light lights up on the lt1 lights thats why it is better to paint the amber red
Old 04-04-2006, 07:28 PM
Sounds perfect... Wack some ls1's. they would be pissed seeing lt1 tailightlights!
Quick Reply: LT1 Tail-light conversion for an LS1......
