Under carriage cleaning tips??
I have a 2000 SS and the underside of the car is real dirty, not only from road grim, oil splashing and the rear diff cover leaking. I have never cleaned the whole underside and its in dire need.
I am determined to clean and make look new what i can, but I need some tips.
Instead of just using simple green,water and wiping things down, what are a few tricks you guys use to get the underside sparkling?
Any info is appreciated.
Yep a lift will be your best friend I use my friends when cleaning the underside of my Z
http://www.01pewterz28.com/undercar.html
My tip is to wear goggles. Some cleaner /gunk is going to drool down on you. It can very easily get in your eyes.
After you gunk it and the ground underneath dries you can get under with some rags and cleaner and fine tune it.
I got my underside pretty clean so far. I decided to clean up the front inner wheel wells, There is so much crap it is crazy. I have gone thru about 6 cans of brake clean and havent even put a dent in it.
I was thinking of borrowing my parents power washer to get the 6 years of crap off and actually get it clean. Do you think that will do the trick?
All of the factory loom was replaced with chrome loom under the car. The chrome is actually easier to keep clean. And thanks for the compliment.
It' still under it's winter Direct Port nitrous build.Should finally be done this month.3 stages of Nitrous,LOUD tunes,a very low stance and CALI weather.
To tell the truth it spent way to much time parked in the garage last year.
Hawk
Hawk
